Jandy VSP - VSSHP220DV2A
vgomez1
72
NTX
Unfortunately, relatively new pump just stopped working. It’s getting power but can’t get it to turn on. Usually connected to iqpump01, but trouble shot it by testing the drive with the RS-485 jumper method - still nothing. Any suggestions? Worked fine very recently. TIA.
If you are certain the pump is getting power on L1 and L2, and the jumpers do not run the pump, then the drive is dead and needs to be replaced. The jumpers are the way to diagnose a dead drive.
Show us p[pictures of the jumpers installed.
Thx for the response. Here’s the pics.
Thx - is driver repair/replacement a diy?
Any suggestions on how to drop water level below pool tile line with inoperable pump besides manually? Perfect timing right before the freeze!
Is it under warranty?
Reactions: vgomez1
I don’t think so - it’s a couple years old and I installed it myself, so I’m sure that voided any warranty.
  • Wow
Reactions: JamesW
Looking to get pump driver repaired/replaced. Thx
The drive is not repairable and usually it is not economical to pay someone to replace the drive.
Better to buy a new pump.
