- Jul 31, 2015
- 110
- Plaster
- Jandy Aquapure 1400
I've been trying to determine if there is an air leak in my system.
When the pump is priming at 3250rpm there are small air bubbles during the entire priming cycle. Here is the priming video:
Then if I drop it down to 1850rpm after priming it turns to a pretty big bubble, about the size of the clear viewer. Around 2750rpm there are hardly any bubbles.
I tried lubing the intake side of the union orings. I cannot access the one feeding the pump without moving the pump back. I'm not sure if I unscrew the pump mounts if I can screw them back in.
I'm wondering if this is normal or should I start buying new orings and unscrewing the mounts to access the other oring?
