Hi, We recently had a pool and a hot tub installed. The hot tub has 8 jets and when we turn on the jets and the blower, the water is spewing out of the hot tub. We are having difficulty getting our pool builder to provide support to us, so I was wondering if anyone here can help us with what are the appropriate settings in the iaqualink app. Just so you know, the distance between the pump and the hot tub is over 40 feet.
Currently I have it set at
Pump /Model - ePump, Application - Aux Pump, Min - 600, Max - 3450 Priming Speed - 2500. Then we go into the Speed Setup and Speed 1 - 2500 - Assign to Aux - Spa Jet, Speed 2 - 750 - Assign to Aux Spa Air Blow.
It doesn't seem to matter what i change, nothing seems to reduce the water spewing out of the hot tub.
Any thoughts or suggestions would be greatly appreciated
