- Jun 26, 2018
- 185
- Vinyl
- Hayward Aqua Rite (T-9)
So had a bypass installed to bypass my heater a couple weeks ago. Yesterday I was adjusting the Jandy valve manually to shift flow away from my heater as I was turning off the heater this week. But the valve moved quite freely vs the usual "clicking" and a bit more force I would typically have to use. Realized that there is a little screw at the head of the arm/valve that had some loose, so tightened it, then everything seemed fine.
But what I was concerned about is, if I moved the arm accidentally and then screwed the top back in, is it possible the valve position has changed? I literally have no idea how to check that.
