I had a company install a pool Fall 2020 that pretty much dug a hole, dropped in a fiberglass form, installed the equipment (Jandy cartridge filter, variable speed pump, and TruClear chlorinator) they happened to have. I arranged the rest, which has been difficult but doable. It was the only way to get a pool at reasonable cost in 2020 in my area. I didn’t choose Jandy, and it was not easy getting everything working, but I worked with what I was given. Now my chlorinator shuts down every so often with a “no flow” error (although there is plenty of flow). I have gone on the internet, and there is a lot of negativity about Jandy and the TruClear. I have already had a bad experience with the local Jandy repair service. Last year I was trying to control my variable speed pump (yes, it really comes with no external speed control). I tried the iQ Pump01 but couldn’t get it to work so I finally made an appointment with the manufacturer recommended repair service. The guy who came claimed he knew about Jandy equipment but didn’t get the controller working. It turned out I knew more about the Jandy equipment than the repair man did. It was $400 for the device and over $100 for the service call down the drain. I added the aqualink control system myself, which does work consistently. Anyway, is this intermittent “no flow” issue usually repairable (I’m afraid I’m going to pay over $100 again for a service call where I can’t trust what I’m told I need) or am I going to have to replace the unit? If replacement is in the near future, what can I replace it with that is more reliable, user installable (assume I have the skills even if my spouse may tell you otherwise), compatible with the aqualink, and reasonably priced?
