Jandy TruClear. How do you remove the power pack cover?
TheVJ
4
I have no display on the panel lcd screen and i suspect the glass fuse inside maybe blown. How do i open it up to check? I removed the 8 screws around there cover but it seems to be attached still at the bottom somehow.
You ever get the cover off?
I did. Besides the screws around the cover that face the front, there are three more screws underneath, what the power cable etc enters the panel. I’ve you get those off the cover comes off. Have to be careful though because the ribbon cable that connects the display to the main board is quite short.
Did changing the fuse work? I'm having same issue. Light is on the panel screen but no info is displayed. Cables are intact. Power is on. No bubbles flowing into my celll but occasionally it shows some life when i hit the breaker but not for long. Still no display info. Didn't think changing the fuse would help but if it did please let me know.
No my power pack had malfunctioned and it had to be replaced. Luckily it was still under warranty.
