Last year, I was having problems generating chlorine with my Jandy salt water system, and I cleaned the cells but still had a problem generating chlorine. I purchase a new Nature2 1400 cell but this did not fix the problem either.
I changed out the Jandy Aquapure sensor and that also did not fix the problem. The am not sure what else to check/change except the cable connectors and the actual motherboard.
RIght now, I have not put any salt in my pool and am using chlorine tablets to get buy. But, I am not getting any error codes for low salinity which seems strange. It only shows 00% with flow. When I had salt in the pool, I did have the cell reversing light on as well. The other strange thing is I am not getting any pool temperature readings on my handheld. I am not sure if this is related or just a different problem.
Any ideas of what could be the problem or what I can check?
