Hope someone can help. I have an Aqualink RS system which I had the computer board changed about 6 months ago. Worked perfect until recently. Now when turn to Spa Mode, the intake valve turns but the return valve does not. Believing it was the old return valve I replaced it with a new Jandy 2440 but still not turning on Spa Mode. I have pressed the Reset button and even switched the dip switches on and off, but still not moving.
What it discovered is that once in Spa mode the Return Actuator has no power (toggle switch on valve doesn’t work), once Spa Mode is turned off, then I have power to the Return Actuator.
Any suggestions?
Any suggestions?
