Jandy ProMP 1.5HP drop in replacement or body only replacement
geepmaley
51
Plano, TX
Hayward Aqua Rite Pro (T-15)
Had a Jandy ProMP 1.5HP on my waterfall Freeze up and lose the threads on the filter basket making the pump unusable during Snowmaggeddon this February. Had just replaced the motor in December 2020, so would really like to just find the pump body to replace (reuse new motor and not have to replumb). Any sources for this?
Or a drop in replacement with same input and output ports and locations?
You should be able to find just the housing to purchase. However, are you sure about the pump model #? Can't find a ProMP.
Is it the waterfall pump?
Or perhaps the PlusHP?
Its a waterfall pump. Its listed in my pool docs as a ProMHP. Pretty sure that just means MHP. sorry about the error. Id love to just find the housing vs a whole pump, but haven't had much luck. It is fairly old (circa 2004)
Unfortunately, as with most Jandy pumps as old as yours, you will find this 1635793641040.jpeg when trying to get the part you want. Had to replace an entire pump for a customer because I couldn't get a replacement impeller earlier this year.
