This issue is driving me crazy. The Jandy LXI400N heater was working fine. Now, turning it on for the first time this season, it won't work. The heater motor starts up and runs for a long time. Finally, after quite a while you hear a click inside, which I assume is the heater calling for gas? Nothing happens. It eventually shuts down and gives off an ignition fault code. It never lights off at all.
I called in an "authorized" repairman. He put a gauge on the unit somewhere inside. The gauge shows gas pressure to spec, but when the heater calls for gas the pressure drops to below spec. He says that there is a problem with the gas supply. I called in a plumber who checked the gas supply and he says it's just fine.
I then called in a repairman from another place to look at the heater. He said it needed a new igniter. He put one in. No change at all. He put the same gauge on the unit that the other guy did and got the same result. He says it's a gas supply issue. I then called in yet another separate plumber. He says there is no issue at all with the gas supply. Arrrggghhhh!
I then called in a THIRD different heater repairman. He's not sure what's wrong. He believes it's the internal solenoid controlled gas valve, which he believes has an internal regulator on it that he believes is faulty. He wants to install a new one and see what happens. That's all well and good except the darned valve is $500!! If it doesn't fix it I'm out $500 and still have an inoperative heater.
Do any of you out there have any ideas on what could be happening here?? I'm about to pull out what little hair I have left.
