Hi. I was about to post in a previous thread ( 2020) but was given a suggestion to start a new thread.
I have an intermittent problem.
The last 2 times I went to use my hot tub my heater failed to work and it flashed “check ignition “. I went out tonight after reading some of these posts to try and get a better description of the problems and after a few failed attempts at starting it finally remained on
Rather than use the remote I put it on service mode. Let the pump get to full speed then selected the heater. The fan came on for about a half a minute then the heat kicked in. About 10 seconds later the heat kicked out. Fan remained on. About 30 more seconds passed and the heat started again. Ran for 10 seconds the kicked off again. 30 more seconds then the heat kicked in again and it stayed on.
Pretty much the same thing happened the last time I tried the heater but after 3 tries it stopped all together then flashed the check ignition. Have to assume it did the same the 1st time it failed to work. It flashed check ignition then too.
Probably completely unrelated but about a month ago my dog was chasing something by the heater ( gecko perhaps ) and thought it was a good idea to chew through a wire harness. It ended up being the high limit wire harness switch assembly (r0457400). I replaced that and it worked fine after. Though I must admit. I didn’t have that white compound they put on the end of each sensor ....conductive grease I expect.
Also worth noting. This was a week after the cold temps we had in Houston a few weeks back. Got down to 10f. No leaks as the pump
Ran continuously for a few days but maybe something crawled into the heater.
I use the hot tub fairly regularly. Minimum twice a month and some times even more frequently so I don’t expect it’s from sitting idle.
Never had gas supply issues in the past so don’t expect it’s that either.
The heater has been relatively dependable. Would love to figure out why the last 2 of the 3 times I went to use it it wouldn’t work.
Appreciate any advice.
Thanks.
mac.
Thanks.
mac.
