Jandy lights burnt out - looking to replace
Nectarologist
642
New York
CircuPool RJ-45 Plus
Hi. I have two Jandy LED lights (pro series I believe). Last year they were out of sync (one was one color while the 2nd light was a different color yet both would rotate colors). This year one burnt out (see picture that is more black) and now the second one lights very very low and illuminates no light unless you look directly at it (but not enough to light the water; pic with no/little black). One thing i discovered is they should have a small screw to keep them secure. They don't and for all I know when the kids are in there they could turn them. I've never discovered them dislodged but they could be moved. I don't know if that would cause the failure though. I don't want to just spend more money if there is an issue besides premature failure. I only use them 10 times a year max so I'm bummed they are not working so soon.
The pictures are not too great but if needed I can try to get better ones. Any advice is appreciated.
Thanks, Chris
All that black is a sign of overheating. You need to pull the light out, open it up, and see what the board looks like.
I think the problem is other vendor lights do not fit Jandy light niches.
