Jandy Levolor consistent .15-.2 gpm leak
shookjn
1
Houston TX
New to the site and looking for some advice on the Jandy Levolor. My unit flows at .15-.2 consistently. How do i know its tge culprit? Well i turn off the water supply to the pool fill and the leak stops. Any guidance on what might cause the small leak? Doesn’t sound like much but about 8000 gallons a month is noticeable.
Welcome to TFP.
Have you followed the flowchart int he Installation Manual?
Mine basically failed after one summer of usage and started leaking. They only have a 1-year warranty and I did not notice the leak until my third summer. I haven't been able to figure out why it's leaking I just don't recommend them to anybody else. Mine leaks even when I turn down the flow to zero on the valve and turn the valve into the off position.
