I have a 3 year old Jandy JXI400 heater. This year the heater would not turn on when the breaker was flipped on for season. I pulled the cover off and found a blown fuse. When I replaced the fuse and turned power back on it burned up the transformer. Called local technician out and he told me the power distribution board was bad. I replaced the PD board and put new transformer in. Same result. Transformer burned up when I turned it back on. The technician came back out and tole me the ignition control board needs to be replaced. Worry he is just guessing on what the issue is. I ordered another (3rd transformer) and wired it in on power side but not on downstream end. Transformer has 25volts on meter. Any idea on what is causing my transformer to burn up when wired back in to fuse and yellow ground?
Dustin
Dustin
