I am installing a propane JXI. I am trying to figure out how to wire the low voltage part to the Pentair Intellicenter.
I am reading the Pentair manual about that - it says remove the heaters fireman jumper - which is that on the Jandy? I'd like to just run a 2 wire from the Jandy to the intellicenter (if possible) to connect to the GAS Heater connection in the Pentair (J2 terminal).
The Jandy documentation talks about 'Connecting to an aqualink control system or remote TSTAT (2 wire connection). I'm assuming this is directions I follow? And then when I set a temp on the Pentair system it's basically just an on/off switch for the heater?
Also - I'm guessing this is against code - but to save space in my panel - can't I just use my 240v double pole 15 amp GFI breaker that I have in the loadcenter for the booster pump to power the heater too? They won't both be running at the same time.... The pump is wired to a relay - I'd wire the heater directly to the breaker.
