- Oct 25, 2015
- 5,828
- Plaster
- CircuPool RJ-60 Plus
Folks,
I've had this weird error about once per year from my heater during the ignition sequence. The start sequence almost completes going through spinning up the fan and heating up the ignighter then there's this loud buzz and it stops the cycle. This cycle repeats 3 times then I get the above error. I traced this using the trouble shooting guide to the air pressure sensor. Removing the yellow wire from the air pressure sensor and replacing it solves the issue. The contacts are in good shape with no visible corrosion, air tubes are in great shape still flexible, no cracks and snug fit. Last year I applied corrosion inhibitor to this connection and it lasted about a year. Is this an annual problem for others? Is there a better fix out there? Naturally this only happens when I have a sore back and really look forward to a hot spa with bubbles! So instead I'm removing the top and bending over the heater to repair it. Aggravating!
Chris
Chris
