Jandy JXI 400N - 2 Years Old - Heat Exchanger Bad???
Megarms
114
Eldersburg, MD
Went to use the spa yesterday and my Jandy JXI 400N would not come on. It started gurgling and now I am being told that my heat exchanger is bad and needs to be replaced. They say it must be due to water chemistry and therefore is not covered under warranty.
So here is the thing. I am meticulous about balancing my water. PH is always in the acceptable range (7.6 - 7.8). The technician says I can only call the 800 number.
What are my options. I am so upset I could scream.
Do you have the Versaflo on your JXI heater?
JXi heaters with VersaFlo factory installed receive a 5-year standard warranty on the heat exchanger.
Do you have this box on the side of the heater? That is the Versaflo valve...
