Jandy IQPUMP01 controller not working, can I still get the pump the start
Guess
1
Groveland, FL
My jandy variable speed pump won’t turn on and my pool guy says it is a problem with the jandy iqpump01 interface pad that connects to the pump. Is it possible to start the pump without having the iqpump01 interface pad connected to it? It was working fine Saturday and then we had a thunderstorm pass through and after noticed the pump wasn’t running and won’t start. I can’t connect to the iqpump01 in iAquaLink anymore either, it has a red status indicator and says “Connection error - cannot connect to device” when I try to go into it on my phone. My wife and I are having a party this afternoon and it would really be great if the pump would at least run to keep the pool clean. Any help anyone can offer would be extremely appreciated!
After thunderstorm last night I now have a non functioning controller. Is there a fix or does it have to be replaced?
Welcome to TFP.
Does the pump have power?
Have you reset the pump CB?
You check for voltage at the pump using a multimeter?
