I am hijacking this post from last year, and thankful that I found it.
I've had my pool for a year and just realized that my installer added Heat Pump as speed 7 as well, which results in 2750 speed whenever the heat pump setting is enabled, even when the pool was heated to the correct temperature. I'm sure my electric bill was affected by this.
As this thread suggested, I have removed the "Heat Pump" on speed label 7. Now, once the pool is heated to the set temperature, the pump speed goes down to the "Pool" speed setting, which is 1750.
Prior to the change, in the app, the "Spa Heater" and "Heat Pump" toggles pretty much worked in unison. When one was on, the other automatically turned on, and vice versa. This seemed odd to me.
Assuming that the the Dip switch S1 8 is correctly set to Heat Pump, is there any need anymore to have "Heat Pump" listed under "My Devices" on the app, and if so, is there a way to remove it?
Also, if you see anything else that you suggest changing, please let me know. I am hoping to take over for the pool guy in the next month or so, and my wife won't be happy if I mess anything up.
