Jandy ePump horrible noise: Defective pump or due to extreme cold?
gocubs418
337
Dallas/TX
#1
I have noticed when the temperature gets down very cold here that the pump begins to sound much louder. I chalked it up to the weather as it goes away as it warms up. However, I am in the last year of my 3 year warranty and want to make sure the pump is going dead on me. I checked both skimmers and they are clean. The pump basket has a little debris but nothing crazy. Temperature is around 30 F right now.
VID_20190207_233639.mp4
Any help would be appreciated, thanks!
Divin Dave
5,189
Longview, Texas
#2
In the big picture, 30F isnt "very cold". Many of us who've had our pools for several years have seen temps in the teens, and dont have any strange noises coming from our pumps. Im only 120 miles East of you and its 26F this morning and no issues here.
If it were me, I would be attempting to use that warranty.
gocubs418
337
Dallas/TX
#4
Sounds like the bearings. Metal expands when it gets warm and contracts when cold so that might be it.
Thank you. I will give the old PB a ring here and see what they say.
Likes: Divin Dave
gocubs418
337
Dallas/TX
#6
Looks like the drive has failed. File a warranty claim for a new motor and drive.
Thanks for the reply.
How do I explain this to the PB? Literally just say "I think the motor and drive are out on the pump or failing"? Will they have diagnostic tools to help prove this? It only makes horrible noises when it gets very cold.
JamesW
12,837
#8
Just tell them that you think that the motor or drive has failed and you would like them to fix it under warranty.
After that, it's up to them to figure it out.
Likes: gocubs418
tstex
1,488
Houston, TX
#10
That sound is definitely not normal, whether it's cold, hot or seasonally nice. Definitely save your video and find a way to time stamp it with the current date/time. When the warranty person comes and does X, make sure you receive a copy of everything that was performed, in detail...also, have the tech examine everything else on your equipment pad to perform an inspection for any unnecessary wear and tear...good luck.
Pls post back after the tech finishes so we can learn what took place - that could help someone else.
gocubs418
337
Dallas/TX
#11
Bad motor bearings... get them replaced under warranty! They may give you a new motor. Replace the seal also, this caused the bearing failure.
Hope this helps.
Chris
Service came out. The pump diffuser was faulty, rubbing badly causing the noise. They replaced it. All better now. Thank you.
setsailsoon
607
Stuart/FL
#12
Thanks for the follow. So I wonder what made the diffuser tear up? For future reference anything that rubs in there makes a nasty noise similar to a bad bearing. Also motor fan can do that.
Glad your problem was solved!
Chris
