I have a new Jandy Check Valve installed to stop backflow into my solar panels when the solar isn't running. It is on the return line from the solar panels.
I see some reverse flow coming from the check valve - not a lot but definitely some. Is this normal or should the check valve stop all reverse flow?
I don't want any backflow into the panels during winter.
I have cleaned it out to make sure there is no debris keeping the valve open.
This seems to be the valve https://www.jandy.com/en/products/valves/check
