Jandy Aquapure Ei - output fault?
Welcome to TFP! Good to have you here :)
It's fair to say that it's normal to replace the chlorinator cell when it reaches the end of its lifespan. The 'cell' (or sometimes 'electrode') is the the assembly inside the clear housing, with the blades, where the chlorine is made, the part that can be cleaned.
7 years is a pretty good run on a salt water chlorinator cell. It's part no. 3 in this manual: https://www.jandy.com/~/media/zodiac/global/downloads/h/h0331400.pdf
Hi there,
We are having the same "output fault" reading on our Jandy Aquapure EI 35. We tried replacing the circuit board and salt cell itself but still having the same issue. Did anyone figure this issue out? Ours is only 5 years old.
Thank you!
