Hello,
My Jandy Aquapure 1400 SWG has been working great since new 18 months ago. Last week it stopped working and while out of town, my pool turned GREEN
I did a SLAM and got the pool back in balance, but the reason I went green in the first place was because the SWG failed. The codes I am getting are 125 and 194. When I look these codes up this is what I find:
Level 1 Code
Level 2 Code
I took the Jandy 1400 SWG off its plumbing and did not see any scaling on the fins. I sprayed it with water and I soaked the unit in a bath of 7/1 water and muriatic acid for about 15 minutes. I hosed everything off real good and put it back together. While I was out there baking in the sun, I went ahead and cleaned my cartridge filters too.
I turned the filter pump back on and once I got flow and turned the SWG on to 60%, I got the above error codes again! Code 125 and 194.
I am not sure what to do next. I live in the Atlanta area and am not sure who I would even call to have the system serviced professionally. I know my local pool store is a bunch of snake oil salesmen.
The system is only 18 months old. The entire pool and equipment was just built in Spring 2018. Any help or advice would be greatly appreciated!
Level 1 Code
125 | Cell needs to be cleaned. | 1. Troubleshoot your tri-sensor to ensure it is working properly. 2. Clean or replace cell if necessary. |
Level 2 Code
194 | Cell current is 85% lower than desired and cell voltage above 19V. | Generates code 125- The cell s dirty or needs replacement |
