I have a Jandy Aqualink RS8 controller and a Pentair Intelliflo VS pump. I installed the pump myself about 5 years ago and it works fine with the Aqualink, but it's just slightly quirky. It makes me believe that I missed a config detail when setting up the pump in the controller, and I'd love to have it right.
The symptoms of things being quirky are:
- When I put my Aqualink into Service mode, all of the (local) buttons on the RS8 work to manually control my gear except the Filter Pump button, which does nothing. Before I moved to a variable speed pump, the Filter Pump button worked as expected.
- When configuring programs, I need to have a program that turns the filter pump on and a separate program to set the VSP speed. This may just be the way it is, but it feels like I may just be working around a config issue that I created.
I've confirmed that the Intelliflow is assigned to filtration in the setup menu, and I don't see any obvious config options that would achieve the desired result.
Any suggestions are appreciated.
Cheers,
Dean
Cheers,
Dean
