- Jul 21, 2013
- 66,092
- Plaster
- Pentair Intellichlor IC-60
This is a thank you to @JamesW. I have a 20 year old Jandy RS8 system and about a year ago I posted something that I didn't think a Jandy system as old as mine had a Spillover mode. JamesW insisted that Dip Switch 3 should enable spillover mode. For 20 years my system has been running with the Pool/Spa return valve slightly open to the Spa when in Pool mode and the spillover always running. Which meant I would have a rising pH all season.
Today I finally had the time to open up my panel and flip Dip Switch 3 and it worked! I also needed to move my Air Blower from Aux3 to Aux7. As Dip Switch 3 makes Aux3 the spillover control. My indoor control panel automatically displayed Spillover when Aux3 was pressed. I reset the cams on the return actuator so spa was fully closed when in pool mode.
I needed to set the label on Aux7 to Air Blower and change the programming of the buttons on my 4 button spa controller for Air Blower now on Aux7.
I set programs to automatically run the Spillover daily to keep the Spa water fresh. I set the Spillover to run 3 times a day - 9AM for 30 minutes, 1:30PM for 15 minutes; and 5PM for 30 minutes. Right now I have a 2HP SS pump. So when the return flow is all directed into the Spa the water flow is vigorous. It seems to me that it will not take much time to turnover the Spa water and refresh it.
Do folks think that is adequate time for the spillover to run daily?
