Hi. I'm new here and tried doing a few searches without much luck on this subject.
I have a Jandy RS6 controller in the house that "locked up" the other day. I hit the reset button on the side and all of the lights came on and stayed on. Made a short jumper to connect the panel out to the main power panel outside, hooked it up that way and played with it for 15 minutes and all functions worked correctly so I assumed bad wiring between the main panel and remote panel. I pulled in new wiring this weekend and hooked everything back up. It worked fine for about and hour, then went unresponsive again. If I disconnect the remote panel, give it a some time and reconnect it will sometimes respond to inputs.
As it sits right now I had it up and running long enough to program in a filter and cleaner schedule. It then went unresponsive but is still starting and stopping the filter and cleaner according to the schedule. It will occasionally update the time and temperature on the display or sometimes freeze up on the date or give the model and revision "HH" number of the equipment.
Everything works fine in "Service" mode on the main panel outside. I'm not too familiar with the system, but it seems like some component is heating up or going out on the remote panel. Is there anything else I can check or individual components I can replace before replacing the entire remote panel?
This is the panel in question in case I'm not describing it correctly.
Thanks.
Thanks.
