My PCB from 2007 appears to have died. I tested the transformer, and I am getting 18vac out of it. I know I should be getting 24 to 28. I definitely have power coming to the sub-panel as I was able to bypass the relays so that I can continue to run my pool manually. So where I am confused is that I am getting power out of the transformer....just not the amount it should be getting. Before I buy a replacement transformer or board, is there anything else that I should check?
Thanks!
Thanks!
