Hi All - I have moved into a home with a Zodiac Z4 with 2 Jandy Actuators to go from pool to spa. I'm up to speed on the actuators and all that happens and have even recently serviced them. I'm looking to solve an issue I'm not sure is possible. My spa is a spill over into the pool. In spa mode, I'd like the diverter valve to be about 90% spa drain, not 100%. I'd like the spa return to still have a little positive volume. My children like to splash and what not and the water can get low, so I'd like a steady but minimal supply. I can do this manually but can't seem to figure out how to clock the actuator without the opposite happening normally (draining the spa).
Thanks in advance!!!
