Okay thank you, that was helpful, so the sealplate is the backplate, I’m guessing I will need to replace that also? I believe I installed the shaft seal correctly. I did not use any lube as the install instructions said to use soapy water. But then I also see people saying I must use a lube sealer? I guess I will pull the motor and replace the seal again. If it leaks again I will need to replace the backplate?Jandy pumps, unfortunately, have a reputation of leaking after a repair/seal replacement. The leak is in the sealplate itself most of the time, sometimes caused by the impeller. Would be very unusual for a properly installed seal to fail so quickly unless the pump ran dry.
