Make sure to check your fence codes. Some don't allow privacy fence with the "back side" towards the pool side as the horizontal pieces can be used to climb over
just something to think about while you are in planning stage.
Yup, was told that from builder, very stupid if you ask me. If someone wants to get in they will.Make sure to check your fence codes. Some don't allow privacy fence with the "back side" towards the pool side as the horizontal pieces can be used to climb overjust something to think about while you are in planning stage.
It more about the small child who can figure out how to get in without understanding or respecting the dangers of the pool.If someone wants to get in they will
That's exactly my point. Easier to climb a 4 foot chain link than 6 foot wood.It more about the small child who can figure out how to get in without understanding or respecting the dangers of the pool.
But then again, the 4 ft chain link at my old house was plenty climbable, especially for a small kid with little feet.
My biggest issue, is there are other homes, with exactly what I want to do. The equipment is on the side of the house right next to the 2 giant ac compressors, the gas meter, and Electric meter. It looks like it belongs there with all the house equipment.Speaking as an officer in our small HOA, that is a very reasonable rule, especially if there are no fences or the fences are open to make it visible from the street. We have block walls but there are restrictions of what can be viewed over the top of those walls. For us it's always what is within reason and we often get neighbors to sign off on variances. Hey, at least yours won't be like the member from the Northeast where the equipment is on the side of the house where there were no fences at all. In that neighborhood anyone could come up and mess with the equipment. I would fence the equipment just to keep it separate from your own yard and handle it that way. My equipment is behind a wall and some landscaping in the corner of my yard behind the pool, totally out of sight.
Cuz you’re the new guy!I knew moving into an HOA neighborhood would be annoying. My biggest issue is how lax they are with everyone, EXCEPT me...LOL. The pics I sent of other pool owners, has them considering the original placement. I will either fence it in, or place some arborvitaes or something to conceal it
Glad to hear this. Your placement seems perfectly reasonable to me. I'm currently leading the ARB for my community, past HOA board member, and past HOA president. It's a thankless job that somebody has to do. So I did it. Unfortunately there are not any requirements that make for an effective HOA board or leadership. It's just luck of the draw and often barely staffed with the few willing to do it. Many participate for all the wrong reasons and this makes it worse. So many (most?) make a lot of mistakes. The only way to change it is to get involved. Most people don't want to do this. Maybe you should give it a whirl... I bet you can make it better.Welp, HOA approved placement of equipment on back corner of the house with landscape screen. Still hoping for end of Jan build.
UPDATE. Builder called, wants to start the dig Jan6!!!!! WooHoo!!! Not looking forward to the yard being destroyed though. I've been through a build before, so know what to expect. I should be swimming by April, if I can make a decision on the heater. Still debating gas or HP. Had a HP up north, because gas wasn't an option. It worked fine, but I am leaning towards its, because I like how quickly it can bring the temp up.
No spas, just the pool. Using it to extend season in beginning, and end. July and August, it wont be used for the most part due to how warm it is here. I also will be using a solar cover to keep heat in overnight.Is the heater just going to heat the pool or is there an attached spa with the pool? What are your goals for heating - swimming earlier and later, making the pool warmer in the summers, etc, etc?
Depending on what you’re trying to achieve, you could go either way …
