Ride, the pool popping is a structural consideration, but without test results we don't know how much should be drained. That, along with other things, greatly affects the structural question. That's what I meant
dalehileman said:Yes Jason I had considered that: While other possible causes might involve my spouse and I since we share many activities, a third swimmer, daughter of a visitor, also was attacked and thus I thought it prudent to replace its entire contents but thank you for your report
Exactly! If you are using trichlor and/or dichlor the odds are that your pool is overstabilzied or will become overstabilized along with the problems it causes. If you have a cartridge filter it is a certainty that will happen within one or two seasons. If you are adding algaecide on a regular basis, get any kinds of algae in the pool, get cloudy water, or need to shock to get rid of chloramine smells on a regular basis then I will bet the farm your pool is overstabilized.
Also, investing in a good test kit that will tell you exactly what your pool needs, when it needs it, and how much it needs will save a LOT of money in the long run
Melt In The Sun said:Dale, you're not going to get any meaningful help without posting test results. They make the world go 'round.
dalehileman said:Thank you bark for that rundown but after 13 years our intuition favors all new water. The rashes might not be due to organics but to interactions among various substances collecting over the years. Had hoped to hear from others who might have emptied theirs but Alas, if its walls collapse I will probably wish I hadn't
And yet any number of experts say that a full drain has nothing to do with your problem and is likely to cause damage (though replacing some of the water is a great idea) and that getting a good test kit is crucial.dalehileman said:Thank you bark for that rundown but after 13 years our intuition favors all new water
Just remember to take pics in case something exciting happens...JasonLion said:If you are going to consistently ignore our advice, why bother asking? If you are so sure of your intuition, then go ahead and do what you please, it's your pool.
dalehileman said:Sorry Sven but didn't see how water test results would impinge on the collapse of its walls
What this means, is "I want to know about replacing my water, not about fixing my water."I couldn't see what test results have to do with collapsing walls
dalehileman said:Ohm thank you for that, I can see some sense in your proposed scheme which would at least dilute the bad stuff so I shall talk it over with My Boss
dalehileman said:Alice thank you most kindly for those remarks which I shall pass along to my Partner. It has been suggested by others and is probably an excellent idea. However we do have an elaborate irrigation system with thousands of feet of tubing etc for some 2.5 acres surrounded by hundreds of trees but at my advanced age and increasing laziness I'm not sure I could work up the ambition to tap into it
Even if I can't amass the energy your posts are nonetheless most welcome and may eventually benefit others faced with the prospect of draining. Meanwhile conducting it to our large sunken compost pit has been without incident of any sort though it's a very slow process using 100 ft of garden hose and so we might advise others to use larger tubing or as you so constructively mention, suspend the pump not so deeply
