Hi Everyone,
In the past I've reached out here to discuss switching over from Jandy Stealth 2.5HP single speed pump to a VSP. Well the time as arrived. The other day I noticed two pin hole leaks in the pump body. I could try to replace the pump body but long term, best bet is to just replace it with a VSP.
Currently I have Zodia/Jandy Aqualink automation but as far as I can tell, my system doesn't have the ability to control a VSP. Previously @HermanTX had pointed out that in the PDA, I could select a VSP, even an Intelliflo but my PDA doesn't have that option as suggested.
So here are my options, as I see it:
Option 1: Upgrade to iAqualink with the IQ30 RS upgrade kit and install a Pentair Intelliflo VSF 3HP (011056). If my understanding is correct, I will be able to control the variable speed settings from the app.
Option 2: Skip the automation upgrade. Install a Pentair Intelliflo3, and use the Pentair Home App to control the pump. Would I have issue when switching over to SPA mode? Would I need to manually switch off the pump, go to SPA mode and then start pump at higher RPM?
Option 3: Upgrade to iAqualink with the IQ30 RS upgrade kit and install a Jandy ePump? This option is my least research option but likely would require least amount of re-plumbing? Suggestions on a Jandy pump?
Any other options?
As seen in the attached pictures, I am concerned about the plumbing as the Heater inlet/outlet are really close to the pump without much clearance for the keypad on top the VSP. Thoughts regarding this?
Any other options?
