Hello!
My winter cover tore, and despite my best efforts, my pool was black as night when I opened it this weekend. I bought this place last year and have been perusing this site since, so I have a basic grasp on the recommendation to SLAM but could use some guidance. My TF-100 kit is on the way.
Here's my levels (tested at the pool store):
FC: 0.44ppm
CC: 3.98
pH: 7.1
TA: 103
CH: 71
CYA: 5
25,000 gallon in-ground pool
In what order should I adjust these chemicals? Do I need to get the TA and pH adjusted before SLAMing? What level should I get the CYA to before trying to SLAM?
How often should I be testing?
I've pulled a ton of gunk out with the leaf net and will keep doing that as often as I have time. Vacuuming to waste as well.
How often should I be backwashing my filter (sand) during this? Should I be taking it completely off to clean it every so often as I saw in one video on here? I've read a bit about adding a little DE to help the process, would you recommend that?
Thank you for your time and help! I'll post progress photos if anyone's interested.
FC: 0.44ppm
CC: 3.98
pH: 7.1
TA: 103
CH: 71
CYA: 5
