Hi all,
I need to slam my pool. Started going green on the walls and corners.
Few years back I slammed with the old pool calculator here. Which I still have. With the new mobile app the suggested FC target level is different. The older calculator has 2 suggested FC fields at the bottom shock and mustard algae values. Shock is 16 and mustard algae has 24 (??).
Now the mobile only has target slam FC value 16.
Not sure why the calculators are different with the same inputs and the mobile only has one slam value. I thought I should use the mustard algae 24 because it’s algae, right? Or am I shocking. Which should I be using?
Thanks everyone
Thanks everyone
