Thanks for the reply Jim.
Would it all work best with an easy touch? If I am away and my wife has to adjust anything would it be easier with one?
I will look into my auto cover's manufacturer to see if they have any recommendations
I have three pools that all have EasyTouch automation systems with build in SWCG power supplies and IntelliFlo pumps. Personally I would not have a VS pump and SWCG without automation, but I have to admit it is not required. Does your car have a key-FOB? Do you need it or do you just love it? Automation is about the same. You don't need it, but once you have it, you will never want to give it back...
Here is my standard blurb about the EasyTouch.....
"It is easy for me to spend your money.. but don't let me talk you into anything. Many people have pools without automation and they work just fine. I do, however, think it is important to know the advantages and the disadvantages of having an automation system.
1. Automation will help you with pool maintenance, but it will not replace the need for you to test your water, understand what you are looking at, and then making sure your water is balanced. (Another reason you need the accuracy of the TF100 test kit.)
2. The main downside to automation is cost. So before going too far down this path, you might ask your PB what it's going to cost. That said, the best time to install automation is when the pool is being built, because all the connections to the system can be made without having to figure out how you are to get power across 50' of new deck. Also, the additional cost, when compared to the cost of the pool, will be miniscule.
3. Automation systems work best when the same brand is used because then the pieces can "talk" to together. So, in your case I would recommend the EasyTouch 4 (or 8) that has a built in power supply for the SWG and generally comes with the SWG and two valves. ScreenLogic2 is an absolute requirement if you want to be able to control things from your PC or Phone.
Here is a list of what I think are the advantages:
1. Appearance. Instead of having a bunch of different boxes hanging on your wall you have one, professional looking enclosure.
2. Circuit Breaker Panel. The bottom half of the enclosure is a circuit-breaker panel where the breakers for your pool equipment (Pumps, Heater, etc.) are located. This panel is also an excellent place to add surge protector, which is an absolute must if you have the Intelliflo pump. Even if you do not get the automation, make sure your PB includes a surge protector for the pump.
3. SWG Control. Without automation, your SWG will have to have a timer, synced to the pump timer so that it does not run when the pump is off. This function is built into the EasyTouch.
4. Spa mode and SWG output. Normally all the water flows through the SWG, so when in the Spa mode, the EasyTouch reduces the amount of chlorine the SWG produces, so that the Spa users are not subjected to high levels of chlorine.
5. Pool Lighting. The EasyTouch allows you to control your pool lighting from your PC and/or from a schedule. This is another reason to add the EasyTouch now. Once your pool light is wired to switches inside your house, it might be very difficult to get the wiring to any automation system.
6. Control of Spill-over and bubblers. Right now I'm sure you are thinking I want that spillover running 24-hours a day because it is so beautiful.. Well, after a few weeks of having your pH go through the roof, you'll appreciate the ability to only turn it on, when you want it on. The same with the bubblers. With the Easytouch, you can program them to run on a schedule for a few minutes a day to keep the everything properly chlorinated or when you want to "show off" to your guests..
7. Relay Control. The EasyTouch 4 has four (really three) relays that can be used to control other things, such as landscape lights. (The EasyTouch has 8 (really 7) relays.
8. Built in Valve controls. The EasyTouch has the ability to control 4 valves. Two work for switching between the Pool and Spa modes, while two others can be programmed to do whatever you might want, like bubbler control. I would note that a lot of bubblers are controlled by manual valves that cannot be automated. You need to be sure to tell your PB that you want Jandy style valves for your bubbler control.
9. Heater Control. The EasyTouch can control your heater.. So, you can be inside and tell your PC what temperature you want the Spa/Pool to be and it will tell you when it is ready.
10. I use mine to control the landscape lighting around my pool.
11. ScreenLogic. ScreenLogic allows you to program the EasyTouch with various schedules. It lets you see most all of the inputs and output to the EasyTouch and lets you decide what you want on/off and in the case of your SWG, lets you adjust the % of output on the fly."
Here is a link to the basic system with the IC60...
https://www.sunplay.com/pentair-easy-touch-control-system-521150
