I had a yellowish substance on my top step about a week ago. At the same time, I started losing chlorine. I decided to slam the pool. I got the chlorine levels up to 18.2 and tried to maintain them at that level for a few days. The pool has always been clear, I passed the overnight test 2 days in a row and so I let the chlorine levels come back down. The chlorine levels went from 18 to 17 on the second successful over night test. The next night it was it was at 14 and I decided to not test early the next morning but tested later in the day on the following day and got a reading of 7.5. Today, I got a reading of 0. I am not sure if I have algae or something else. From what I have read online, yellow algae should brush off quite easily. This yellow substance required to be scrubbed off with a wire brush.
Any help would be appreciated. I have my readings below and then the results from the 2 different pool stores.
My current readings right now are as follows:
FC 0
CC .2
pH 7.2
Alk 60
CYA is 30
CH is 160
I went to 2 different pool stores to see if they had any ideas and to check my numbers against their figures.
First store
FC 0.05
CC .08
pH 7.5
Alk 48
CYA is 48
CH is 142
2nd store
FC 0.4
CC .0
pH 7.2
Alk 78 (adjusted alkalinity 48)
CYA is 100
CH is 262
They thought the yellow substance might be pollen or my inability to hold chlorine is from fertilizer that was applied by a farm near by.
FC 0
CC .2
pH 7.2
Alk 60
CYA is 30
CH is 160
First store
FC 0.05
CC .08
pH 7.5
Alk 48
CYA is 48
CH is 142
2nd store
FC 0.4
CC .0
pH 7.2
CYA is 100
CH is 262
