This morning I took out the cell, soaked it in Diluted Muriatic acid, in a bucket and then rinsed , cleaned the Tri-Sensor, and put it back.
Right after the cell cleaning, for about an hour , or almost two hours I was getting Flow, the Cell was ON - so normal, desired operation.
Four hours later now, it shows "waiting", the "Flow" light is off (both on the LCD panel, and on outside indicator)
Now, It shows error code "185". Also shows "HH" when the temperature button is pressed.
I'm not sure why it starts of working normally after a cell clean, then stops working in about an hour or so.
If the Salinity tri-sensor was bad, why would it show normal working for about an hour after clean + restart. Is there something in the panel that I need to reset/calibrate?
My filter is quite clean. The pressure is also normal on the filter. Last week I added liquid chlorine and pool shock to get rid of Algae. (cleaned filter twice after & added DE) Now water looks good, with no algae, but I'd like to stop adding chlorine, and let the automated system take care of it. Ph is normal right around 7. I've already added stabilizer.
This is the latest status. On the Aquapure Display, Salinity shows as "- -". After this I measured Salinity with a separate meter.. It shows 3300. I've also added some salt , about 10 lbs of salt.
NOT WORKING.
Two hours l
Below are the pics after I had just cleaned the sensor and the cell. (WORKING)
Picture of my Salinity sensor and cell
NOT WORKING.
Two hours l
