Issues with Maytronics Sigma
SteveK52
285
Taylors South Carolina
My Maytronics Sigma purchased in may of 2023 started acting up the other day, first stopping mid cycle and giving me a communication error on the app, suggesting to unplug the cable and reinstall. I did this and it appeared to solve the problem. Later in the day long after the cycle would have finished the robot started all by itself. The next morning I placed it back in the pool and the impeller would spin for a second or two and then stop. I contacted a local pool store that is authorized to work on them and asked if they would do warranty work even though I didn't purchase it there. They said there would be a $100.00 charge to do the warranty work. I opted to pay the $100.00 vs paying to ship it to Maytronuics. They called me the next day and said they had ordered a new cable as one of the three lugs on the motor was badly corroded. When I asked what would cause the corrosion he indicated high CH, I said because I had a vinyl pool I didn't think the CH level was critical. He started to lecture me on proper chemistry levels. When I Look back (I have not checked this in a while as I didn't think it was important for my vinyl pool) at my CH data, I see several readings at 325 and then 100. I have a five year old SWG that I replaced recently and looking at the plates there is zero build up and they have never been cleaned. Does this make any sense?
Steve,
All the connections are 'sealed', but seals can and do sometimes leak.
Water chemistry, or having a saltwater pool, has nothing to do with the failure..
It takes very little water to corrode the connection where the cord connects to the motor housing..
I have seen several, where the pins on the motor housing were corroded so badly they could not be repaired.
Reactions: Mdragger88
