Hello everyone, hopefully someone could help me with my issue.
I just reopened my pool. I let it cover all winter. When I removed the cover I discovered a lot of leaves on it (a lot of wind here) and the water was beginning to be a little green.
I thought "no worry, I will slam, it should be good"
I tested the ph, 7.4, CYA, 10, alka, 90.
And I put 3 gallons of bleach (10%) for my 30k pool to reach the slam level.
It was last evening, this morning I want to test the chlorine level with dpd method. No chlorine. The mix powder/water doesn't turn pink at all.
I considered my dpd powder bad so I brought the water to a pool store to test it, same, a very little of chlorine.
May be my CYA is too low so I added 4 tab of chlorine to add some CYA. But it was the night, so it should be a issue?
Tonight I put 3 gallons more of bleach (10%) but it seems to be the same.
I am worry because my pool is turning greener.
So what is happening? My CYA too low and doesn't hold the chlorine and the chlorine literally disappear?
Or the bleach is bad? (in this case at least the tabs would react on the dpd test, right?)
Thank you in advance for your help!
