In poolmath select bleach & your percentage- no sense in doing the toilet paper math on the packagesOkay, so I just got home and tested everything. Here's where my numbers came back at:
7.4 pH
120 PPM Alkalinity
0 CH (again)
.4 PPM FC
.8 CC
So it looks like I'm low on Free Chlorine. I picked up the liquid chlorine, and based on Texas suggestion of 4-5 PPM of liquid chlorine on a 20,000 gallon pool, I'd need to add about 104-130 oz of liquid chlorine. It says on the bottle that 13 oz. is 1 PPM per 10,000 gallons, so just doing that basic math. I purchased a box of Pool Essentials Liquid Chlorine as suggested.
Does this sound about right? And then the recommendation is to add an additional 30PPM Of stabilizer afterwards?
Just want to make sure I've got this all down before I start dumping chemicals. When I use the Pool Math app, it doesn't give me an option to select liquid chlorine as the sanitizing agent.
It's the HTH 3 in 1 shock.What is the “shock” that u added/have? Cal hypo, trichlor, or dichlor?
Go ahead & Add 5ppm worth of liquid chlorine now. Pour slowly infront of a running return, brush the area.
The SWG is not on yet, no. That's supposed to happen this week or next. We are just limping along until then unfortunately.It won’t hurt anything to add lc now. You need adequate fc to prevent a lagoon.
Also add the cya/stabilizer via the sock method.
The cal hypo adds calcium & fc. It contains no cya.
Do not add clarifier- that is only a bandaid that will gum up your filter. The cloudiness is likely from algae. You need to do an Overnight Chlorine Loss Test at target fc levels FC/CYA Levels.
I am also not understanding how they are claiming u have scale when you have no ch but at the same time they are suggesting u add cal hypo which adds ch & too much ch is what can cause scale …
We’re a few pages in so remind me, is all your equipment hooked up yet?
But the pump is up & running?The SWG is not on yet, no. That's supposed to happen this week or next. We are just limping along until then unfortunately.
Yes, pump is on and running 24/7. Waiting on salt and to power the SWG, which is supposed to happen when the builder does "pool school" at the end of the process.But the pump is up & running?
You are just awaiting salt & to power on the swg?
Please be advised that the swg will not solve your woes if u have algae.But the pump is up & running?
This is great advice. We have established that the PB does not have the expertise of pool chemistry, so adding anything based on his suggestions are likely going to be against good practices, and the TFP recommendations. As if we didn't have enough, the two statements below are great examples of what not to do.....U will likely have to decide whether to follow the pb’s chemistry advice or the TFP recommendations - they generally don’t jive with one another. Many people decide that the “included” services from the pb are not worth the headache & take over chemical maintenance themselves to prevent being stuck with a swamp in their backyard whilst waiting at the the leisure of the pb
After talking with the PB last night, he recommended I add one bag of shock, which treats 13,500 gallons
Both PB and his maintenance tech are telling me to just add a clarifier to the pool, and leave the three chlorine tablets in the float device.
None at all. You need chorine in there, stat. The cloudiness likely has more to do with algae than anything else, with a low CYA level and your reported chlorine levels, something has got to be growing in there...Are there any downsides to adding in the liquid chlorine now
0 CH (again)
my FC is at .4
