Pool has been uncovered all winter, won't get in to why that is, but just FYI. The water yesterday was reasonably clear with some dirt on the bottom of pool. Due to recent rains, the water level was high, so I vacuumed to waste until the water level was normalish, then vacuumed what little dirt (discoloring on the bottom) remained to the filter. I backwashed/rinsed 2 times before I started vacuuming to filter then once again after I was done. Pressure hadn't really climbed, but I just wanted to have a clean start. My CYA tube got busted so I couldn't really check the level (one on the way) but EVERY year, my CYA level at the start of the season is 0. I assumed the same so I added the correct weight of Stabilizer in a sock to bring the CYA to 30 and added enough pool chlorine (recently purchased) to bump the FC to 14 (shock level is 13 for CYA of 30). Again, the water was pretty clean looking.
This morning when I got up to go check the status of the pool, expecting it to look somewhat better, it was quite a greenish color. I'm not sure if it was just settled out of the water and sitting on the bottom or not but it appeared to be. I was running short on time, so I checked FC with the drop test and it came out at 14, which is where it was last night. So nothing is eating the chlorine but the water is green. What might be the cause of this? I'm going to have the wife brush the pool today and then check the FC again.
