- Jun 14, 2018
- 208
- Vinyl
- Hayward Aqua Rite Pro (T-15)
Yes. If the sample stays clear, you have no FC.Is the goal to have the sample remain pink before adding the R-0871?
Thanks, Jim.S,
If this is a fresh fill, your CYA can't be 100 already.
Might want to look at that one again.
Jim R
S,
Do not use Cloromax, because of the additives.
I suggest you go to Home Depot or Lowes and buy Liquid Chlorine. Often called Chlorinating Liquid.
Jim R.
This means your CYA is low, not high. The tube shows lower numbers as you approach the top. You need to add CYA. Pool School saysI just threw in 100 as a high number because I filled the tube up but could still see the black dot. The laminated instructions don't say what to do if this happens.
Solid/granular cyanuric acid (CYA) should be placed in a sock and the sock put in the skimmer basket or suspended in front of a pool return. After adding CYA you should leave the pump running for 24 hours and not backwash/clean the filter for a week. Squeezing the sock periodically will help it to dissolve faster. Test and dose chemicals in your pool assuming the amount of CYA added is in the pool according to Pool Math. CYA can be tested the day after it is fully dissolved from the sock.
