- Nov 12, 2017
- 11,927
- Plaster
- Pentair Intellichlor IC-40
Unless somebody has any tips, I'm going to run the pump up to 2000 RPMs or so, cut open the bag, pour it out directly into the pool, walking along the coping of just the shallow end, then brush it around until it disappears. I figure dumping any into the deep end will just be that much harder to brush.
Nope, next time I'll do it the exact opposite way! Broadcasting it around the entire perimeter was just more work. Didn't seem to get it to dissolve any faster. That's probably more about time than location. I ended up sweeping it into a pile and just working it around like that.
Next time I'll dump it into the deep end, which in my pool is very bowl-like, then sweep it as if to gather it all into one small bump. Then just work the bump with short strokes until it's gone.
The brand I used worked fine. Took about half an hour.
I'll run the pump 24 and check the salt level in a couple days. Then add as need to get to 2800-2900...
