Is this algae?
Apr 13, 2018
17
Estero, FL
Auto Chlor SMC-30
I somewhat messed up my pool in a matter of a week. Our pump failed and we bought a Pentair Superflo VST pump. We have a Chlorsync CS30 SWCG as well. Since getting the new pump, I'm running it 24 hours at day, and my salt system is running 24 hours a day, set to 19% output. The pump was running at 1700 for 24 hours, and I just bumped it up to 2250 for 12 hours and 1700 for 12 hours. For whatever reason, I can't keep my chemicals balanced. I never had a problem before, and I don't know if it's because I am running the pump 24/7 now, or if that's just a coincidence. My FC is at 5. My PH is between 7.8 and 8.2, and my alkalinity varies from 80 down to 60. I can't keep my numbers in check. I test every other day, and I'm either adding acid or baking soda, depending on which reading is off. Now we have these yellow marks in the corners of the pool, that we never had before. I attached pictures. I don't know what to do.
10,600 gal, IG plaster, Pentair Superflo VST pump, Pentair Clean and Clear 150 filter, Chlorsync CS30 SWG, Pentair Ultra Temp heat pump, Betta SE solar skimmer, Poolmaster 5-way test kit, Taylor Sodium Chloride K-1766 test kit
What happens when you brush them? Looks like algae. Brush them, what happens?
First thing to do is get a recommended test kit. You need it. Link-->Test Kits Compared
If the stains go away when you brush it is algae. Add 3ppm of liquid chlorine a day until the test kit arrives.
When it arrives, follow the SLAM process. You need one of the recommended kits to perform the process. Link-->SLAM Process
If it doesn't go away when you brush, use our stain identification guide:
Test your FC at whatever time the sun leaves the pool surface. See what your low FC for the day is.
Get the test kit, add the 3ppm per day, then SLAM.
Likely you didn't follow this (link at the end) and keep FC in range for your CYA...as you have no reliable test kit to measure your FC and CYA, you can't maintain the FC required. Link-->FC/CYA Levels
I will buy a better test kit tomorrow. It looks to be around 4.
Chances are you won't find one of the recommended test kits locally.
Test Kits Compared
Your pool is a major investment - invest in a quality test kit to properly manage your pool water.
The TF-Pro Salt would suit you well and contains more of the test that we as residential pool owners do.
Here is a comparison of the kits (thanks go to @Newdude )
