- Jan 16, 2017
- 176
- Plaster
- Autopilot Digital PPC4 (RC-52)
My PB was supposed to install three floor returns. I already have a separate main channel drain. I was very pleased about it all until I came home after the plaster job and saw what appeared to be three drain covers protruding from the bottom of the pool (one in the shallow end, one at the break and one in the deep end; again all separate from my main drain). Am I wrong in thinking that floor returns should be flat and level (even slightly depressed) with the pool floor? This is what the covers look like:
This is what I expected:
If what I expected is what is supposed to be there, are there things I can do to retrofit what they have done? The issue I suspect now is that the mounting ring for the current covers is fixed in the plaster and so I have to have a cover that matches. The floor returns I have seen are not as big as these covers and so would not match the mounting bracket and holes they put in the pool. Maybe some online can create a custom lid for me that is flat and resembles the floor return. I really don't want to stub my toes and step over these monstrosities.
