I have a 14k gallon indoor plaster pool. Right now I have the following:
- 3 ppm Free Chlorine
- 7.9 pH
-35 40 TA
- 390 Calcium
- 0 CYA
- 1400 ppm Salt
- Temperature around 65~95 depending on whether I wanna swim
- LSI: -0.02 ~ -0.13
Swimmer load is typically very low. If I don't do add anything to the pool, I only need to add a bit of chlorine every week or two to maintain that range (very little direct sunlight). TA seems to settle around that level, and pH as well. That pH is a little higher than most people like to keep it at, but considering my chlorine levels and the fact I don't need any CYA, it seems still effective at sanitizing.
Conventional wisdom is to keep TA higher, but if I do, I'm forced to constantly add acid to keep ph at an acceptable level to keep LSI good. The current balance is very stable requiring minimum intervention.
The question is: am I doing something wrong? Could this chemical balance come to bite me later?
- 7.9 pH
- 390 Calcium
- 0 CYA
- 1400 ppm Salt
