- May 12, 2022
- 44
- Fiberglass
- Jandy Truclear / Ei
I asked for help with opening last year but I ended up using a pool company so I apologize if I'm asking the same question. I don't think I can screw up anything too badly with opening vs. closing but want to be sure I'm doing it right.
I had a pool company close my pool and they put plugs on the two returns and a gizmo in the skimmer. They blew the water out of the pipes before plugging. They also removed drain plugs from my cartridge filter and pump (and I think heater). I removed the pressure gauge and cartridge filters and stored inside.
My question is in what order do I remove the winter plugs? Do I remove the two return plugs first and then the gizmo or visa versa? Does it matter? Once they are removed, I have a good idea of how to put the other items back in the original spots.
Thanks!
Thanks!
