Is there a salt that’s better than others?
Nikilyn
0
1,340
Gilbert, AZ
Pentair Intellichlor IC-40
We just refilled our pool and need to put more salt in. What do I need to look for when buying it? Is there a specific brand thats’s best or one to stay away from?
+ 1. HD/Lowe’s have it by the hot water heaters year round. It’s $5-ish a bag instead of $8. The crystals are bigger so it takes a whopping 20 more mins to dissolve. You have to let it mix for a full day either way so it’s kinda a moot point.
I prefer the water softener salt but have bought the regular pool kind many times while I was already somewhere else that had it in front of me. No need to waste an hour leaving and going somewhere else to save $3 a bag when you only need one or two.
The pain in the butt to me was having to take the truck to get 10 bags in the spring. The car is just SO much comfier. So last year I took the car and strapped 2 bags into every seat like they were 80 lb kids and 2 in the trunk like groceries. Problem SOLVED !! :)
Our HD has the salt outside so its dirty. I will have to see if they have any by the hotwater heaters but we don't have hard water.
Home Depot sells Diamond Crystal Solar Naturals. It's perfect for your SWG and inexpensive.
img_20210108_140538-jpg.172475
+1 on the HD salt. By me I can order it online, pull up, have it dropped in the truck and I'm on my way. Not that picking up a few bags when I need them is all that tough, but if all I need are a few bags, the curbside pickup, along with the fact the price per bag is actually less than regular softener salt, is the way to go for me.
Good idea, if your doing a new startup might not be a bad idea to have it delivered 😜
Reactions: Nikilyn
Softener salt, in large quantities, can add quite a bit of dirt to a pool. You’ll want to sweep and vacuum after addition. If you ever looked at the brine tank of a household softener, they have to be cleaned regularly to remove all the sand and grime build up. Some types of softener salt also contain sodium hexametaphosphate (SHMP) as an anti-scaling agent for iron and other dissolved metals. You want to avoid softener salts that have additives. Pool grade salt is more expensive, about $2-$3 more per bag but it is usually higher purity, contains less solids and is a finer grain than softener salt making it dissolve faster.
HD’s curb side pickup has been lifesaver for me. Earlier this year I had a back injury (couldn’t even stand or walk for awhile) that even now prevents me from lifting 40# bags.
  • Sad
Reactions: markayash
I wish we still could get a good quality pool salt around here.
I use to use Superior Crystal Pool Salt by US Salt. It was great! Very clean and fine grained for quick dissolving. But then everyone around here switched to AquaSalt. I tried that once and it released a bunch of awful grey scum into the water. It also says it has some kind of “stain fighters” additive, but no one, including the manufacturer, could tell me what “stain fighter” is added to this salt. I also tried Mortons from Walmart, but it was dirtier with a lot of pebbles in it.
So I’m using the Diamond Crystal Solar Naturals from HD. While not as good as the Superior Crystal Pool Salt I use to use, it’s better than the other pool salts available around here.
I don't know how widespread its distribution is, but I bought a bag of AquaSalt LLC product from a Houston area (Katy) Ace Hardware, and assuming it remains available, it is my new salt. It's labeled Food Grade, and that may explain why it's very fine and dissolves rapidly. In fact, when I pour into the deeper end of the pool (5-6 feet) it never reaches the bottom. No brushing necessary, as it's just gone. The label further specifies it is just for chlorine generators and not for human consumption. I see the company is in Houston, so I don't know where else it's available. I don't remember what I paid, but it must have been reasonable...because reasonable is my price limit.
  • Wow
Reactions: Nikilyn
My local pool store sells Aquasalt in NJ. Works well.
I pay $12/bag for the convenience when I need a bag or two.
Given TFP’s stance on knowing what one is adding to their pool, I’m surprised no one here seems to be bothered by AquaSalt’s mystery stain preventer additive. Not to mention the yucky grey scum it added to our pool, but perhaps I got a bad batch that caused that.
I saw that, read the ingredients, and figured I would give it a try. I have not seen any ill effects.
However my pool takes 25 bags of salt. When I need to add salt from a fresh fill I use Mortons Pool Salt. To top it off with a few bags of salt I figured the added ingredients, if there are any, will be small and diluted in my pool.
I never saw that.
I hadn't noticed that "natural stain fighters" on the bag. I've only used one bag, and I haven't seen any sign of a grey scum in the water, on the waterline, or in my skimmer socks. Now I'm getting nervous about it. Anyone else have the scum problem or have any idea what the "stain fighters" are? The website says 99.9% sodium chloride, and the MSDS has no mention of anything but sodium chloride.
I've sent an inquiry to the company asking about the additive.
