I have a smarter spa salt water generator and I can adjust the low and high range of chlorine in the tub (I confirm this with Taylor test). I add bleach after every use to ensure my free chlorine does not drop below the minimum I set.
If I set the minimum to a low level like 0.5 or 0.25 and the chlorine never drops to zero, is the chlorine still effective at killing bacteria and processing waste at low levels like 0.25 (as long as it does NOT drop to zero) OR is there a minimum level of chlorine required for the chlorine to be effective?
Would a Nature2 stick help a this lower range OR not as long as the Chlorine does not drop to zero?
(this is a bit more of a theoretical question because I know most people are not in a position to be able to manage the low range of chlorine on an ongoing basis)
