Hi,
I am looking at the electrical connections that the installer made in the jandy control panel and I just noticed that the jandy variable speed filter pump is wired to the line side, together with the LINE voltage cables. In other words, as currently wired the pump would always receive 220V (yes, both load lines are connected as such).
This does not seem normal. At least not according to the manual. Does it always need to be energized and the RS-485 actually switch it on? The manual is not clear on this, but I thought the pump was supposed to be connected to the load size of the relay and therefore energized only when the iaqualink computer activated the relay.
Thanks!
Thanks!
